aditya deshmukh
Beginner
Cisco Switch Model with 24 Ethernet 1000 Mbps and 24 SFP 1000 Mbps ports
Hello Everyone,
Please suggest Cisco Switch Model with 24 Ethernet 1000 Mbps + 24 SFP 1000 Mbps ports in single chassis?
1 ACCEPTED SOLUTION
Philip D'Ath
Advisor
You should probably use the new Cisco Catalyst C9407R Chassis.  These are replacing the 4507R.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9400-series-switches/datasheet-c78-739053.html
Another option would be to use a 48 port SFP/SFP+ switch and put in 24 x 1000BaseT SFP's.
You could consider a Cisco Nexus 3548 (which has SFP+).
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-3548-switch/data_sheet_c78-707001.html
If you dropped the requirements of a single chassis you could use a stacked pair of Cisco 3850's.
2 REPLIES 2
Philip D'Ath
Advisor
Thanks Philip !
We are going for Cisco Nexus 3548 (which has SFP+).
