11-14-2019 07:40 PM - edited 11-14-2019 07:52 PM
Hi All,
I am looking for basic clarification on Cisco Stack Switch connection to Firewall HA pair. I am planning to have a Firewall Active/passive HA pair with port aggregation configured with LACP. Do i need to configure separate Port-channel in Switch for Active Firewall and Standby Firewall Or can connect both firewall in same port channel. If both works, what is the pros and cons of each design.
Sankar
11-15-2019 12:53 AM
- LACP expects both ports to be active, that means if yoy choose for Active/Standby solution , then it's better to have 2 LACP pairs too.
M.
11-15-2019 02:48 AM
You have to use two channels on the switch as the ASA/FTD in HA is not a single system from the LACP view.
