Cisco Switch SG-300,SG-500
ziyadps
HI,
does cisco SG-300 and SG-500 support cisco meraki MR36 wireless AP ?
balaji.bandi
They are inter compatible ?
what you looking PoE to powerup look at the datasheet and Model which you need to buy can power up Meraki AP.
BB
ziyadps
we have sg 300 and sg 500 switch. when we connect meraki mr 36 access point to the port access point not powering up
MR 36 Need :
https://documentation.meraki.com/MR/MR_Overview_and_Specifications/MR36_Datasheet
check SG 500 or 300 datasheet :  (enable CDP and LLDP and check)
Using a combination of CDP, LLDP-MED, Auto Smartports, and VSDP (Voice Services Discovery Protocol - a unique Cisco protocol), customers can deploy an end-to-end voice network dynamically. The switches in the network automatically converge around a single voice VLAN and QoS parameters and then propagate them out to the phones on the ports where they are discovered. For example, automated voice VLAN capabilities let you plug any IP phone (including third-party phones) into your IP telephony network and receive an immediate dial tone. The switch automatically configures the device with the right VLAN and QoS parameters to prioritize voice traffic.
High-Power Power over Ethernet Plus (PoE+)
Cisco 500 Series switches support the Power over Ethernet Plus (PoE+) standard (IEEE 802. at), providing up to 30 watts per port. The power is managed in a smart fashion such that only the amount of power the endpoint needs is delivered to it and not wasted. As a result, the switches can support devices that require more power, such as dual-band 802.11n wireless access points, video-based IP phones, surveillance cameras, and more.
PoE capabilities simplify the deployment of advanced technologies by allowing you to connect and power network endpoints over a single Ethernet cable, without having to install separate power supplies. Cisco 500 Series switches are also fully backwards compatible with IEEE 802.11af PoE and previous- generation Cisco legacy PoE protocols.
https://www.cisco.com/c/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/c78-695646_data_sheet.html
BB
switch not
