08-29-2012 05:49 AM - edited 03-07-2019 08:35 AM
I am able to reset the switch, so that it reads:
switch:
switch:
But when I type flash_init
Initializing Flash...
flashfs[0]: 13 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 3612672
flashfs[0]: Bytes used: 1114112
flashfs[0]: Bytes available: 2498560
flashfs[0]: flashfs fsck took 3 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
aýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýýý
The switch then turns to crap. I was able to add IOs on to every other switch besides this one. I need the flash to initialize to start the process. Any ideas?
Solved! Go to Solution.
08-29-2012 06:46 AM
hi Garrett,
once it happened to me too. it was with a 7200VXR so quite different machine but i was able to fix the issue formating the flash memory. before doing this check very well if you can do it....
it worked for me
Alessio
Update: first good doc https://supportforums.cisco.com/thread/2015724
remember Xmodem after that!!!
08-29-2012 06:46 AM
hi Garrett,
it worked for me
Alessio
08-29-2012 08:03 AM
Ahh thank you... I typed in
#switch format flash:
And it seemed to reset the flash
The xmodem transfer is working now thank you
