Cisco Switch
Robo123
Hi ,
I am Trying to config 3850 switch running IP Services and doing policy routing on vlan But it seems switch is taking the command but but when I look back with a show run interface vlan <**>, it is not present there.Kindly suggest.
Reza Sharifi
It may still not be supported. Have a look at this link:
https://community.cisco.com/t5/switching/route-map-not-taken-on-3850-ip-services/td-p/2578478
ip next-hop recursive and ip next-hop verify availability features are not available and the next-hop should be directly connected.
see link for more info:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-9/configuration_guide/rtng/b_169_rtng_3850_cg/b_169_rtng_3850_cg_chapter_01010.html
