Cisco Switches 9500 esstential licenses can be stack
kick534
Beginner
Beginner
Hi team
I have 2 X 6807 Cisco Switches in VSS as a Core
we purchased for distribution 2 X Cisco 9500 switches with essential licenses ( now with essential licenses 9500 series switches i cannot configure Stack-wise virtual link )
please advise how we can make high availability between core to distribution
distribution 9500 series switches what should i configure so they can have HA with Core switches
balaji.bandi
CAt 9500 only can be done with Stackwise virtual - as you mentioned License is the limitation.
You can do other way is Make it Layer 3 Distribution, so Access layer can peer with Distribution using OSPF or EIGRP ( again Look at the License).
BB
distribution 2 X Cisco 9500 series i will use FHRP any protocol to connect with core switch.
from distribution Cisco 9500 series how can i make redundant link to Access layer please explain ??
You need to run between 2 X  9500 - OSPF or EIGRP your choice, i prefer OSPF
Access switch - 2 Uplink, 1  go to Switch 1 9500 and 2 uplink go to switch 2 9500 - run OSPF between Dist and Access switch, OSPF can take care of routing equal cost and failover.
Layer 3 SVI for user VLAN in Access switch, this is a standard 3 tier setup.
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/Campus/cisco-campus-lan-wlan-design-guide.html
BB
