Highlighted
dal Participant
Participant
Cisco switches show filters - how to do AND
Hi.
I'm trying to filter some output from my switches.
For example, I want to show only switchports marked with TV, and are connected.
But how to do it?
If I write "show int status | inc TV|connected, it lists all connected ports, even if description is TV or not.
It seems that the | (pipe) is used as an OR expression. But what I need is an AND expression?
Can it be done?
Thanks.
1 ACCEPTED SOLUTION
Highlighted
VIP Advisor
Try with: show int status | i (.*TV.*connected)  also please check the following link:
https://cciernstricks.com/cisco-pipe-command-examples-with-regular-expressions/
Please rate the comment if the question was answered or useful
1 REPLY 1
Highlighted
VIP Advisor
Content for Community-Ad
