cisco switches
Yashesh
Hello Team,
We would want to know if the below devices of CISCO have the feature of generating net flow and dataflow.
Do these these devices do generate data and netflows ???
CISCO CBS350-48P-4G-UK
CISCO C92001-48P-4G-E
CISCO C93001 4X10G
Kindly confirm.
Best Regards,
Yash
5 Replies 5
Reza Sharifi
For basic NetFlow v5 or v9 on Catalyst switches, any license will do. If you want full support for Flexible NetFlow, you’ll need either a DNA Essentials or DNA Advantage license. The following configuration is for NetFlow v9, so anyone with a Catalyst 9000 series switch should be able to follow along.
https://www.noction.com/blog/cisco-catalyst-netflow-configuration
There is also s-flow for CBS350
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/Administration-Guide/cbs-350/status-and-statistics.html
Thanks Reza for prompt response.
So is it confirmed that all the below 3 devices, they support V5 or V9 flows?
CISCO C93001 4X10G
IF yes, please confirm and also share what licenses each of these devices anyone should buy so that these devices support V5 and V9 flows.
Looking forward for your feedback, swift confirmation and guidance.
Best Regards,
Yash
For the type of license needed, talk to your sales rep. They will be able to tell you what you need and provide the cost.
Ok, we will talk to the sales rep. for licenses.
can you confirm all these 3 models have V5 and V9 flows facility? Please confirm.
Yash
Have a look at the link I posted.
For this example, let’s imagine you have a small remote site where you want to monitor all IPv4 traffic. This configuration is using a Catalyst 9300 with Network Advantage licensing, so NetFlow v5 and v9 NetFlow features are included, but not Flexible NetFlow. This configuration should be customized as needed but should provide a good basis for your network.
