cisco Switching and UC540
jcajuste
i have a layer 3 switch configure with multiple vlans. i have a uc 540 directly connected to a switch port on the L3 switch.
i can ping the uc.
Core#ping 172.16.15.254
Sending 5, 100-byte ICMP Echos to 172.16.15.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
Core#
however i can't can't traceroute to the uc.
Tracing the route to 172.16.15.254
VRF info: (vrf in name/id, vrf out name/id)
1 * * *
2 * * *
i can traceroute to a device directly in the same vlan as the uc.
Tracing the route to 172.16.15.23
1 172.16.15.23 0 msec 0 msec 8 msec
extended ping works
Core#ping
Protocol [ip]:
Target IP address: 172.16.15.254
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
Core#
extended ping works , extended traceroute does not see below.  any help will be appreciated.
Core#traceroute
Protocol [ip]:
Source address: 172.16.15.1
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
1 * * *
2 * * *
3 * *
Core#ping
Protocol [ip]:
Repeat count [5]:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/17 ms
Core#ping
Protocol [ip]:
Repeat count [5]:
Extended commands [n]: y
Source address or interface: 172.16.15.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Packet sent with a source address of 172.16.15.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/17 ms
Core#
Giuseppe Larosa
Hello @jcajuste ,
if UC540 is directly connected traceroute does not add any additional info
post
show ip arp 172.16.15.254
then with the resulting MAC address
show mac address-table address <address> and you will find out where the UC540 is connected to.
However, to answer to your question the UC540 may be configured in such a way that it does not send back ICMP unreachable messages to the L3 switch and this makes the L3 traceroute to fail
Traceroute relies on receiving back ICMP unreachable message of different type TTL expired until a no port on host on final destination host.
Hope to help
Giuseppe
Giuseppe Larosa
Hello @jcajuste ,
post
Hope to help
Giuseppe
