cisco vpn on iphone5 iso 7.0.3 dont work !!!
Dr.X
Explorer
Explorer
hi all ,
i have iphone 5 with ios 7.0.3 (11b511)
the proiblem is when i use  cisco vpn on iphone , it is connected on iphone ,
but  dont work !!!!
and the subnet that should be reached from vpn  ,  is un accessible and cant ping it .
note that i can ping it when no vpn connected !!!!!
in corresponding ,
when i use the same config  on my pc with installed cisco vpn software ,  the vpn work fine !!!!
wish to help
regards
Rashid Thompson
Beginner
Beginner
Do you have your wifi turned on?
Hi , sure I have , I have made a snapshot for my iPhone after connecting the vpn
Ah I see. Is "Ahmd" a part of your internal network?
Recognize Your Peers
