cisco WS-C3560X-24P - have issue with STP.
Hi All,
we are facing issue with the stp which is causing the interface to bounce every 60 seconds or less, need help identify the issue?
.Aug 25 15:37:05.969: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3116 moving from blocking to learning
.Aug 25 15:37:05.969: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3177 moving from blocking to learning
.Aug 25 15:37:05.969: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3178 moving from blocking to learning
.Aug 25 15:37:05.969: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3254 moving from blocking to learning
.Aug 25 15:37:10.624: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3116 moving from forwarding to disabled
.Aug 25 15:37:10.624: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet0/17 deleted from Vlan 3116
.Aug 25 15:37:10.624: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3177 moving from forwarding to disabled
.Aug 25 15:37:10.624: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet0/17 deleted from Vlan 3177
.Aug 25 15:37:10.624: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3178 moving from forwarding to disabled
.Aug 25 15:37:10.624: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet0/17 deleted from Vlan 3178
.Aug 25 15:37:10.624: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3254 moving from forwarding to disabled
.Aug 25 15:37:10.624: %SPANTREE-7-PORTDEL_SUCCESS: GigabitEthernet0/17 deleted from Vlan 3254
.Aug 25 15:37:11.136: %DTP-5-NONTRUNKPORTON: Port Gi0/17 has become non-trunk
.Aug 25 15:37:11.631: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to down
.Aug 25 15:37:12.637: %LINK-3-UPDOWN: Interface GigabitEthernet0/17, changed state to down
.Aug 25 15:37:17.796: %LINK-3-UPDOWN: Interface GigabitEthernet0/17, changed state to up
.Aug 25 15:37:18.820: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3116 moving from disabled to blocking
.Aug 25 15:37:18.820: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3177 moving from disabled to blocking
.Aug 25 15:37:18.820: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3178 moving from disabled to blocking
.Aug 25 15:37:18.820: %SPANTREE-6-PORT_STATE: Port Gi0/17 instance 3254 moving from disabled to blocking
.Aug 25 15:37:19.298: %DTP-5-TRUNKPORTON: Port Gi0/17 has become dot1q trunk
.Aug 25 15:37:19.826: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/17, changed state to up
.Aug 25 15:37:20.975: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3116 moving from learning to forwarding
.Aug 25 15:37:20.975: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3177 moving from learning to forwarding
.Aug 25 15:37:20.975: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3178 moving from learning to forwarding
.Aug 25 15:37:20.975: %SPANTREE-6-PORT_STATE: Port Gi0/19 instance 3254 moving from learning to forwarding
.Aug 25 15:37:20.975: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 3116
VLAN0040 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 6 last change occurred 1w1d ago
from Port-channel3
VLAN0041 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 2 last change occurred 1w1d ago
from Port-channel3
VLAN0252 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 7 last change occurred 1w1d ago
from Port-channel3
VLAN3002 is executing the rstp compatible Spanning Tree protocol
from Port-channel3
VLAN3104 is executing the rstp compatible Spanning Tree protocol
from Port-channel3
VLAN3111 is executing the rstp compatible Spanning Tree protocol
from Port-channel3
VLAN3116 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 34557 last change occurred 00:00:16 ago
from GigabitEthernet0/19
VLAN3177 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 34550 last change occurred 00:00:16 ago
VLAN3178 is executing the rstp compatible Spanning Tree protocol
VLAN3192 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 0 last change occurred 3w1d ago
VLAN3254 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 34555 last change occurred 00:00:16 ago
VLAN3800 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 8 last change occurred 1w1d ago
from Port-channel3
VLAN3801 is executing the rstp compatible Spanning Tree protocol
from Port-channel3
0 Replies 0
