Unnikrishnan A K
Beginner
Cisco WS-C3560X-24T-S switch Single strand bidirectional fiber not working
Hi, I am trying to connect 2 3560X-24T switches using single strand bidirectional fiber with GOXS-BI5312-20D SFP module. the sfp is third party, and it is not working. the interface is not coming up also. Any one have any idea how to make it working?? I dont have any cisco make sfp module for this. Unnikrishnan
1 ACCEPTED SOLUTION
Leo L
VIP Community Legend
Could be a faulty optical module.
13 REPLIES 13
Philip D'Ath
Advisor
Does "show inventory" recognise the SFP?
show inventory result is as follows
NAME: "GigabitEthernet1/2", DESCR: "1000BaseLX SFP"
PID: , VID: , SN: *****************
it doesnt show the PID and VID, I believe it is because of non cisco..
Leo L
Could be a fault with the fibre optic cable.
HI,
I have tested the fiber optic cable, and sure it is fine. I have another sfp for using the fiber pair. that works properly. I am using a strand from that pair for testing bidirectional sfp.
amikat
Rising star
My view is that for the BIDI SFP connection you would need different modules at each end, ie when using GOXS-BI5312-20D at one end you would need GOXS-BI3512-20D at the other end. These can operate in pairs with their TX/RX wavelengts swapped. Eg. GOXS-BI5312-20D TX operates at 1550nm, RX at 1310 nm, while GOXS-BI3512-20D TX operates at 1310 nm, RX at 1550 nm.
Best regards,
Antonin
Georg Pauwen
VIP Master
on a side note, try the two commands below (I am not sure if the 3560 supports them though):
3560(config)# no errdisable detect cause gbic-invalid
3560(config)# service unsupported-transceiver
Thanks for reply..
"service unsupported-transceiver" command not available..
not working with first command..
might be a hidden command, did you type the entire line in and hit ENTER ?
If you remove the SFP and plug it back in - what appears in the log?
@amikat, I will try that..
@philip, will check it..
Leo L
thanks for all replies..
suspects faulty sfp. will update the post after replacing it.
~Unni
Hi more over a solution, atleast I found that the fault is with module, and sorry for the delay in response.. This much time took to replace the faulty module... :)
