Cisco WS-C4500X-16 is going on ROMmon every time after rebooting.
karinn001
Beginner
Beginner
I have a WS-C4500X-16 switch and its going in ROMmon mode every tome when i hard reboot it. Kindly suggest me what i need to do.
cisco#dir
Directory of bootflash:/
No files in directory
1692037120 bytes total (1691938816 bytes free).
cisco#show bootflash: all
-#- --length-- ---------date/time--------- path
1605988352 bytes available (98304 bytes used)
Filesystem: bootflash
Mounted: Unknown
show ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.06.04.E RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 12-Feb-16 22:40 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG11
cisco uptime is 26 minutes
System returned to ROM by reload
System image file is "tftp://10.0.4.33/cat4500e-universalk9.SPA.03.06.04.E.152-2.E4.bin"
Jawa Revision 2, Winter Revision 0x0.0x41
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-C4500X-16'
License Level: entservices Type: Permanent
Next reboot license Level: entservices
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
Processor board ID JAE193403N1
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from Reload
1 Virtual Ethernet interface
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Leo Laohoo
VIP Community Legend VIP Community Legend
i need the steps how to load the ios by bootflash
Command:  copy tftp://10.0.4.33/cat4500e-universalk9.SPA.03.06.04.E.152-2.E4.bin bootflash:
16 Replies 16
Leo Laohoo
Reboot the appliance and post the entire bootup process.  I want to see why it goes into ROMmon.
Hi Leo,
After changing the config register i have again going into the Rommon mode.
config-register = 0x2102
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment varia ble.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' c ommand.
rommon 1 >
Leo Laohoo
Could not find a valid file in BOOT environment variable.
The config-registry value is 0x2102.  The last octet of "02" stands for "boot the IOS image found in the boot variable string".
Because the appliance is unable to find the file stated in the boot variable string, the appliance goes into ROMmon.
Leo,
If the second paragraph is right so what would be the steps to resolve this issue.
(Because the appliance is unable to find the file stated in the boot variable string, the appliance goes into ROMmon.)
Leo Laohoo
Change the config-registry value to 0x2101 and then load the IOS into the bootflash.  Reboot and the appliance should boot the IOS.
I have change the config-register 0x2101 to 0x2102. Switch has again into
ROMmon mode.
here is the logs of the switch
* Welcome to Rom Monitor for WS-C4500X-16 System. *
* Copyright (c) 2008-2014 by Cisco Systems, Inc. *
* All rights reserved. *
Rom Monitor (P) Version 15.0(1r)SG11
CPU Rev: 2.2, Board Rev: 9, Board Type: 108
CPLD Mobat Rev: 2.0x549a.0x59a4
Chassis: WS-C4500X-16
MAC Address : ec-bd-1d-c0-4a-7f
IP Address : XXXXXXX
Netmask : XXXXXXXX
Gateway : XXXXXXXX
TftpServer : XXXXXXXX
Non-Redundant system or peer not running IOS
System Uplinks & Linecards have been reset!!
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Management Ethernet Link Up: 100Mb Full Duplex
******** The system will autoboot now ********
config-register = 0x2101
Autobooting using the first file from bootflash.....
No bootable image found !
boot: can not determine first file name on device "flash1:/USER"
Autoboot using first file from bootflash failed.
rommon 1 >
Should i load the ios by tftp server, or by bootflash command moreover bootflash command is not working.
Leo Laohoo
Change the config-registry value to 0x2101 and then load the IOS into the bootflash.  Reboot the appliance.
This is saying there is not valid IOS found in the bootflash.
cisco#show version
software.
ROM: 15.0(1r)SG11
cisco uptime is 11 minutes
Last reload reason: power-on
export@cisco.com.
Last reset from PowerUp
I have change the config-reg but i need the steps how to load the ios by bootflash
cisco(config)#boot bootldr bootflash:
Missing file name
file name means ios file name (cat4500e-universalk9.SPA.03.06.04.E.152-2.E4.bin)  or something else.
If i reboot the device it will again go into the came condition
ROMmon mode
Leo Laohoo
Leo,
Thanks allot for supporting switch has boot from bootflash
Loading image !!!!!!!!!!!!!!!!!!!!!!!
Checking digital signature....
[bootflash:/cat4500e-universalk9.SPA.03.06.04.E.152-2.E4.bin]
Digitally Signed Release Software with key version A
Rommon reg: 0x00084F80
Reset2Reg: 0x00004200
Image load status: 0x00000003
Leo Laohoo
Happy to see it's finally working.
IP Address : XXXXXXXXX
Netmask : 255.255.255.0
Gateway : XXXXXXXX
For help on choosing a boot method, type 'confreg' command.
rommon 1 >
Leo Laohoo
Recognize Your Peers
