cisco WS-C4507R-E i not found restarted up time
naitikpatel
we have two switches 1> cisco WS-C4507R-E   2> S 2960
A4750_1 uptime is 3 days, 9 hours, 58 minutes
Uptime for this control processor is 3 days, 9 hours, 58 minutes
2>  S 2960
_S2960_2 uptime is 3 days, 9 hours, 59 minutes
System restarted at 01:25:49 ist Wed May 1 2013
As per above mention log i found in two different switches.
My question is why i not found "System restarted time in 4507R "?
5 Replies 5
Leo Laohoo
Because your 4507R doesn't have a valid timesource.
What happens if you do a "sh clock"?  What's the output?
   We already configured NTP on both switches
and by " sh clok " command  I got correct time.....
Can any one reply ......on my last update
Naitik,
You can view the last reload time and reason for reload using "show ver"
Hi all,
I have the exact same problem. for some reason my cisco WS-C4507R-E keeps restarting ('System restart') daily.
What could be the reason for this system to be restarted?
Show clock shows the correct time. it is configured to get time from the NTP server.
Show version details are as follow.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(53)SG1, RELEASE SOFTWARE (fc1)
ROM: 12.2(44r)SG5
Darkside Revision 4, Jawa Revision 9, Tatooine Revision 140, Forerunner Revision 1.21
MABL3DC_DCSW01 uptime is 22 hours, 10 minutes
Uptime for this control processor is 22 hours, 10 minutes
System returned to ROM by reload
System restarted at 16:17:29 MY(KL) Tue Apr 1 2014
System image file is "bootflash:cat4500e-ipbasek9-mz.122-53.SG1.bin"
Last reload reason: Unknown reason
Show logging details are as follow.
*Apr  1 08:12:55: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:12:55 UTC Tue Apr 1 2014 to 08:12:55 MY(KL) Tue Apr 1 2014, configured from console by console.
*Apr  1 08:12:57: %SYS-5-CONFIG_I: Configured from memory by console
*Apr  1 08:12:57: %SYS-5-RESTART: System restarted --
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 30-Oct-09 16:46 by prod_rel_team
*Apr  1 08:12:57: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Apr  1 08:12:58: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.17.200.11 Port 514 started - CLI initiated
*Apr  1 08:12:58: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.1.80 Port 514 started - CLI initiated
