06-16-2015 04:00 AM - edited 03-08-2019 12:34 AM
I just tried to establish a fiber (MM) connection between a c2960x and a c2960x using SFP-10GBase-SR modules on both sides, but link is not coming up
Both side link not come up and while check getting
TenGigabitEthernet1/0/1 is down, line protocol is down (notconnect)
All on the same ports and modules and also different ports an modules per switch.
Any suggestions on why a connection between the c2960x and the c2960X doesn't work?
Switch#show version
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2)EX5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 21-Feb-14 05:54 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(2r)E1, RELEASE SOFTWARE (fc1)
Switch uptime is 3 hours, 14 minutes
System restarted at 07:01:58 UTC Tue Jun 16 2015
System image file is "flash:/c2960x-universalk9-mz.150-2.EX5/c2960x-universalk9-mz.150-2.EX5.bin"
--More-- agree to comply with applicable laws and regulations. If you are unable
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-48FPD-L (APM86XXX) processor (revision F0) with 524288K bytes of memory.
Processor board ID FCW1912B1EP
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
50 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 88:90:8D:D0:26:80
Motherboard assembly number : 73-15964-02
Power supply part number : 341-0527-01
--More-- Motherboard serial number : FOC191184YN
Power supply serial number : DCB190768FP
Model revision number : F0
Motherboard revision number : C0
Model number : WS-C2960X-48FPD-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC19121J68
System serial number : FCW1912B1EP
Top Assembly Part Number : 800-41461-01
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : CMMLJ00ARB
Daughterboard revision number : A0
Hardware Board Revision Number : 0x12
Switch Ports Model SW Version SW Image
* 1 52 WS-C2960X-48FPD-L 15.0(2)EX5 C2960X-UNIVERSALK9-M
Configuration register is 0xF
Switch#show idprom interface te1/0/1 show int gi1/0/50 capabilities0 capabilities capabilities capabilities capabilities capabilities capabilities capabilities capabilities t capabilitiese capabilities1 capabilities/ capabilities0 capabilities/ capabilities1 capabilities
Model: WS-C2960X-48FPD-L
Type: SFP-10GBase-SR
Speed: 10000
Duplex: full
Trunk encap. type: 802.1Q
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
06-16-2015 05:27 AM
There is a bug in this version that causes the fiber ports not to come up. You may want to upgrade to 150-2a, which is the latest version and test again. Also, are you using Multimode cable as well?
BTW, usually a reboot will fix the issue, but obviously that is not a very good solution.
