[Cisco3560x]Ping PC is destination unreachable
bondol_hendra
Beginner
Beginner
I have topology like :
Core 3560x ---------------------- Baseline Switch Manage 2924 ------------------ Switch Unmanage ------------------ AP ------------------ Client (A) (B)
Vlan 2 = 192.168.2.x/24
Vlan 3 = 192.168.3.x/24
If client A have ip address 192.168.2.2/24 gateway 192.168.2.1
and client B have ip address 192.168.2.3/24 gateway 192.168.2.1
Client B can ping client A but result is destination unreachable
Client A can ping gateway in core 3560x the same client B
But if client C in switch manage with vlan 3, client C can ping client A and the result is reply.
what happened?
please help me,thanks before, sory for bad my english.
7 Replies 7
InayathUlla Sharieff
Whats the port config connecting between core and base line?
are the ARP learning on th core?
Can you execute show arp on every switch  and verify where the ip address 192.168.2.2 is not associated with the mac address
port config connecting between core and baseline is switchport trunking encap dot1q, switch mode trunk...
Akash Agrawal
If i understand it correctly, client A can ping client C which is in different subnet/vlan but can not ping client B which is in same subnet. Please provide config of switch where client A,B are connected. Is there any port security applied. And show arp also from client A and B.
Akash
Yes...
Client A to client C can ping in different subnet.
Client A to client B can not ping in same subnet..
Client C to client B can ping in different subnet..
but is Client D same with subnet client C can ping..
Sometimes reply sometimes destination unreachable..
if i traceroute from core to client B is timeout
but i ping from core to client B is reply...
Please advice...
Amit Singh
Please check Windows Firewall on the PC's and then work upwards on the network level if Windows FW/Anti-virus and any other security softwares are disabled.
firewall windows n AV is disabled. Not other security software.
