Client-identifier / Hardware Address PROBLEM
Didier1966
Level 5
Level 5
On my 1841 router I have some FIX IP for static devices , but one of them does not want to receive a IP that I give him.
The product always take one of the DHCP server and also work with this , but the IP that I give is never taken.
Here bellow some part of the script :
The MAC and PRINTER are working fine but MLGW , always take one from the DHCP server.
I have try to connect a CISCO 610N and WRT54GL , both of them can gove the right IP to the MLGW , I do not know what I do wrong.
I have try HARDWARE ADDRESS IEEE802 and CLIENT-IDENTIFIER , but non of them work.
ip dhcp pool MAC
   host 192.168.10.50 255.255.255.0
   client-identifier 0100.2312.1c0a.39
ip dhcp pool PRINTER
   host 192.168.10.20 255.255.255.0
   client-identifier 0100.242b.4d0c.5a
ip dhcp pool MLGW
   host 192.168.10.10 255.255.255.0
   client-identifier 0100.04f3.0158.b3
I have also tried to remove the 01 in front of the MAC , like you see here in the list bellow , but no difference.
ROUTER1841#sh ip dhcp bind
Bindings from all pools not associated with VRF:
IP address          Client-ID/     Lease expiration        Type
    Hardware address/
    User name
192.168.10.6        0004.f301.58b3          Dec 04 2010 11:47 AM    Automatic
192.168.10.10       0100.04f3.0158.b3       Infinite                Manual
192.168.10.20       0100.242b.4d0c.5a       Infinite                Manual
192.168.10.50       0100.2312.1c0a.39       Infinite                Manual
192.168.100.20      0100.2241.353f.5e       Infinite                Manual
192.168.100.66      0100.089b.ad17.8f       Infinite                Manual
Any Help is welcome
I have give this server a FIX IP now , so it still work , but not the way I want it
Best Regards,
Didier
5 Accepted Solutions
if you put the address in the excluded addresses and in a manual binding scope your server won't get no ip address.
I just wanted to know which problem you had because it was not very clear.
Regards.
Also try these two basic points.
1.Clear arp cache from DHCP Router.
2.Unplug and Replug the network cable on end device. some times the end device will not clear its cache properly.
margalla
     Hardware address/
     User name
This looks like the client is not sending a client-id so the address is being assigned based on the hw-address.  You haven't shown the configuration you used for the hw-address so we can't say why that may not have worked.
Perhaps try  0004.f301.58b3 as the hw-address in your MLGW pool and show the results if it is still bad.
Also you might want to sniff the DHCP packets so we can see exactly what the client is asking.
If you don't have a sniffer, you could possibly try one of these IOS tools:
Router IP Traffic Export Packet Capture  Enhancements
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/ht_rawip.html
Embedded Packet Capture
http://tools.cisco.com/squish/5C213
Try this:
ip dhcp pool MLGW
hardware-address 0004.f301.58b3
Regards.
PS : WHY DO SOME COMPUTERS NEED "Client-identifier" and others "Hardware-address" ?
Dynamic Host Configuration Protocol
http://www.ietf.org/rfc/rfc2131.txt
"DHCP defines a new 'client identifier' option that is used to pass an
explicit client identifier to a DHCP server.  This change eliminates
the overloading of the 'chaddr' field in BOOTP messages, where
'chaddr' is used both as a hardware address for transmission of BOOTP
reply messages and as a client identifier.  The 'client identifier'
is an opaque key, not to be interpreted by the server; for example,
the 'client identifier' may contain a hardware address, identical to
the contents of the 'chaddr' field, or it may contain another type of
identifier, such as a DNS name.  The 'client identifier' chosen by a
DHCP client MUST be unique to that client within the subnet to which
the client is attached. If the client uses a 'client identifier' in
one message, it MUST use that same identifier in all subsequent
messages, to ensure that all servers correctly identify the client."
So the client chooses to send a client-identifier or not. If it does the server has to use it. If it doesn't the server looks at hw-address instead.
12 Replies 12
cadet alain
you wang a static ip for this device, not a manual binding like you did so you must be sure to configure this server with this static ip and exclude it from the scope in your dhcp server.
Is this your problem?
I hope I understand you correctly , I have removed the IP ADDRESS that I have put in the MLGW FIX POOL , but it is still the same
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.100.1
ip dhcp excluded-address 192.168.1.250 192.168.1.254
ip dhcp excluded-address 192.168.10.10
ip dhcp pool vlan10
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 8.8.8.8
   lease 5
ip dhcp pool vlan20
   import all
   network 192.168.20.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.20.1
   lease 5
ip dhcp pool vlan30
   import all
   network 192.168.30.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.30.1
ip dhcp pool FIX-IP
   host 192.168.100.66 255.255.255.0
   client-identifier 0100.089b.ad17.8f
   client-name FIX-IP
ip dhcp pool TEST
   host 192.168.100.20 255.255.255.0
   client-identifier 0100.2241.353f.5e
ip dhcp pool internal
   network 192.168.100.0 255.255.255.0
   dns-server 192.168.100.1
   default-router 192.168.100.1
ip dhcp pool vlan1
   network 192.168.1.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.1.1
   lease 5
ip dhcp pool MAC
ip dhcp pool MLGW
Regards.
Hello Cadetalain,
What I would like to archive is to send all FIX IP from the CISCO ROUTER to :
PRINTERS
NAS DRIVE
CAM
WEB SERVER (MLGW) RUNNING UNDER LINUX
All of the above have the ability to have a FIX IP , but I prefer to do it from the ROUTER.
All of them work even my MAC and PC's here in the home , the ONLY one that give me troubles is the WEB SERVER.
He receive always a IP from the FIRST DHCP POOL VLAN10 and NOT from the DHCP POOL MLGW , like you can see here bellow.
I have tried the MAC ADDRESS WITH and WITHOUT the 01 in front of the MAC ADDRESS , without success.
ip dhcp pool vlan10
   import all
   dns-server 8.8.8.8
   lease 5
ip dhcp pool vlan20
   import all
   dns-server 8.8.8.8
   lease 5
ip dhcp pool MAC
ip dhcp pool MLGW
   client-identifier 0004.f301.58b3
Best Regards,
Didier
I have try all the above without success
Do not loose too much time on my case , you have other priorities
I just like to know why on some COMPUTERS or SERVERS or NAS drivers it works , and why it does not work on others.
I have put some DEBUG ON , to see what is going on , but I can see that DHCPOFFER send 192.168.10.3 instead of 192.168.10.10
Here bellow the result :
ROUTER1841#sh debug
Generic IP:
  IP Address activity debugging is on
DHCP server packet debugging is on.
DHCP server redundancy debugging is on.
NETBIOS:
  NetBIOS packet display debugging is on
DHCPC:
  DHCP client activity debugging is on
Condition 1: vlan 10 (1 flags triggered)
Flags: 10
Condition 2: ip 192.168.10.10 (0 flags triggered)
ROUTER1841#
*Dec  4 22:35:04.159: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/0, changed state to down
*Dec  4 22:35:05.159: %LINK-3-UPDOWN: Interface FastEthernet0/0/0, changed state to down
*Dec  4 22:35:08.114: %LINK-3-UPDOWN: Interface FastEthernet0/0/0, changed state to up
*Dec  4 22:35:09.114: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/0, changed state to up
*Dec  4 22:35:22.253: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/0, changed state to down
*Dec  4 22:35:23.257: %LINK-3-UPDOWN: Interface FastEthernet0/0/0, changed state to up
*Dec  4 22:35:24.257: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0/0, changed state to up
*Dec  4 22:35:30.684: DHCPD: DHCPDISCOVER received from client 0004.f301.58b3 on interface Vlan10.
*Dec  4 22:35:30.684: DHCPD: Sending DHCPOFFER to client 0004.f301.58b3 (192.168.10.3).
*Dec  4 22:35:30.684: DHCPD: creating ARP entry (192.168.10.3, 0004.f301.58b3, vrf 0).
*Dec  4 22:35:30.684: DHCPD: unicasting BOOTREPLY to client 0004.f301.58b3 (192.168.10.3).
*Dec  4 22:35:30.744: DHCPD: DHCPREQUEST received from client 0004.f301.58b3.
*Dec  4 22:35:30.744: DHCPD: Appending default domain from pool
*Dec  4 22:35:30.744: DHCPD: Using hostname 'mlgw.telenet.be.' for dynamic update (from hostname option)
*Dec  4 22:35:30.744: DHCPD: Sending DHCPACK to client 0004.f301.58b3 (192.168.10.3).
*Dec  4 22:35:30.744: DHCPD: creating ARP entry (192.168.10.3, 0004.f301.58b3, vrf 0).
*Dec  4 22:35:30.748: DHCPD: unicasting BOOTREPLY to client 0004.f301.58b3 (192.168.10.3).
margalla
     Hardware address/
     User name
Hello Margalla,
Thank you also for this useful information , here bellow I have put the FULL config :
version 12.4
service password-encryption
hostname ROUTER1841
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable password 7 05080F1C2243
aaa new-model
aaa authentication banner
THIS SYSTEM IS SOLELY FOR USE OF AUTHORISED USERS FOR OFFICIAL PURPOSES
aaa session-id common
clock timezone gmt+1 1
clock summer-time gmt+2 recurring last Sun Mar 2:00 last Sun Oct 3:00
dot11 syslog
no ip source-route
ip cef
ip dhcp pool vlan10
   import all
   dns-server 8.8.8.8
   lease 5
ip dhcp pool vlan20
   import all
   dns-server 8.8.8.8
   lease 5
ip dhcp pool vlan30
   import all
   dns-server 8.8.8.8
ip dhcp pool FIX-IP
   client-name FIX-IP
ip dhcp pool TEST
ip dhcp pool vlan1
   dns-server 8.8.8.8
   lease 5
ip dhcp pool MAC
ip dhcp pool MLGW
no ip bootp server
ip domain name dri
ip host SW12 192.168.1.252
ip host SW24 192.168.1.251
ip ddns update method DynDNS
HTTP
  add http://[email protected]/nic/update?system=dyndns&hostname=mlgw.dyndns.info&myip=//[email protected]/nic/update?system=dyndns&hostname=mlgw.dyndns.info&myip=
interval maximum 1 0 0 0
interval minimum 1 0 0 0
crypto pki trustpoint TP-self-signed-2996752687
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2996752687
revocation-check none
rsakeypair TP-self-signed-2996752687
username Admin privilege 15 secret 5 $1$gAFQ$6WYuTY9G/
archive
log config
  hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh port 8096 rotary 1
ip ssh version 2
interface FastEthernet0/0
description DMZ
ip ddns update hostname mlgw.dyndns.info
ip ddns update DynDNS
ip address dhcp
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description INTERNAL$ETH-LAN$
ip address 192.168.100.1 255.255.255.0
no ip proxy-arp
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
switchport access vlan 10
spanning-tree portfast
interface FastEthernet0/0/1
switchport access vlan 20
interface FastEthernet0/0/2
switchport access vlan 30
interface FastEthernet0/0/3
switchport mode trunk
interface Vlan1
ip address 192.168.1.250 255.255.255.0
ip nat inside
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Vlan30
ip address 192.168.30.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
ip dns server
ip nat inside source list 101 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.10.10 80 interface FastEthernet0/0 8095
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
access-list 101 permit ip 192.168.30.0 0.0.0.255 any
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
no cdp run
control-plane
banner exec
WELCOME YOU ARE NOW LOGED IN
banner login
WARNING !!!
IF YOU ARE NOT :
Didier Ribbens
Please Leave NOW !!!
YOUR IP and MAC address will be LOGGED !!!
line con 0
speed 115200
line aux 0
line vty 0 4
access-class 5 in
privilege level 15
rotary 1
transport input telnet ssh
line vty 5 15
access-class 5 in
rotary 1
scheduler allocate 20000 1000
ntp clock-period 17178443
ntp server 66.27.60.10
end
Best Regrds,
Didier
Try this:
ip dhcp pool MLGW
Regards.
I did a compilation of all the information :
REMOVED THE CABLE
CLEAR THE ARP-CACHE
CLERA THE IP DHCP BINDINGS
And what you told me to do :
p dhcp pool MLGW
and IT WORKS.
Thank You ALL
Best Regards,
Didier
j.beckner
Level 3
Level 3
In case this helps anyone, I have found that Zebra Bar Code printers use the hardware-address not the client-identifier when configuring the IOS dhcp static reservation
