clock timezone command issue
alexals
Hello all,
Am not sure whether the issue I have now is a well-known bug in IOS or something else. I need to get advice from you all about 'clock timezone' command.
I'm currently working in one of service provider company and having roughly around 200 unit of Cisco ISR 2921/K9 router. These routers having exactly the same specification/configuration on hardware. I noted that majority of these routers having one weird issue whereby configuring 'clock timezone' command doesn't get registered in the configuration. Only a handful of these routers are able to accept that command.
Due to this, most of our router doesn't have correct time synchronization (few hours behind the current time). I tried many times to enforce 'clock timezone MY 8 0' on those routers but fail. I did execute 'show run | sec clock timezone' command and I expect it is in the configuration but it is not exist at all.
What could it be? All these routers are able to synchronize time with our NTP server but majority of it doesn't registered correct time due to 'clock timezone' issue.
INFO:
Model: Cisco 1921/K9 router
IOS version: C1900 Software (C1900-UNIVERSALK9-M), Version 15.3(3)M6, RELEASE SOFTWARE (fc1)
Kindly advise and thank you in advance.
Alex
Peter Paluch
Alex,
Can you try using a timezone name that contains at least 3 characters? It looks like a timezone name consisting of only 2 characters is too short:
Router(config)#clock timezone MY 8 0
*Jan  4 05:52:51.563: %SYS-3-TIMEZONE_INVALID: Invalid timezone name
Router(config)#
Router(config)#clock timezone MYT 8 0
Router(config)#
*Jan  4 05:53:02.223: %SYS-6-CLOCKUPDATE: System clock has been updated from 05:53:02 UTC Thu Jan 4 2018 to 13:53:02 MYT Thu Jan 4 2018, configured from console by console.
Ideally, you should use the official timezone name abbreviation:
https://en.wikipedia.org/wiki/List_of_time_zone_abbreviations
Can you give this a try?
Best regards,
Peter
6 Replies 6
Peter Paluch
Alex,
Router(config)#
Router(config)#
Best regards,
Peter
Hi Peter,
It works but I didn't get this error messages '*Jan 4 05:52:51.563: %SYS-3-TIMEZONE_INVALID: Invalid timezone name' before. It just shows nothing after I entered the previous command. Hmmmm...
Anyway, thank you very much for your suggestion ! 😄
Alex
Hi Alex,
Yeah, I've used 15.5(2)XB 7200 IOS just to quickly test the clock timezone command behavior, and it looks this IOS version reports errors more diligently.
Best regards,
Peter
Hi.
I am trying to change the time zone on a cisco 2960, but on inserting  timezone, it is showing unrecognize command. what should i do please?
Joseph,
Can you paste the exact command you are trying to enter, and the response from the switch? We need to understand what exactly you are trying to configure, and how does the switch respond.
Thanks!
Best regards,
Peter
kastamonu.university
Frequent Visitor
Frequent Visitor
This topic is very old but I am writing because I had a similar problem and found the solution randomly.
You can try putting a "+" or "-" sign in front of the time zone. Like +8, -3.
