Cluster / IP Duplicate / HELP
Rodrigo Bezerra
I have two servers connected to Nexus, these servers are sever with windowns 2008 failover cluster. ativivo / standby.
I want the standby server 1 and server 2 becomes active it appears I can not duplicate ip, and I'm sure there is not ip duplicate.
Anyone have an idea
Thank you.
10.65.6.1 serve 1
10.65.6.2 serve 2
10.65.6.101 vip ip
CORSWBETANXS01# sh ip arp | inc 10.65.6.
10.65.6.1       00:00:15  6cae.8b2c.2d88   Vlan312
10.65.6.2       00:00:15  6cae.8b2c.2354   Vlan312
10.65.6.21      00:00:18  6cae.8b2c.2b6c   Vlan312
10.65.6.22      00:00:15  6cae.8b2c.272c   Vlan312
10.65.6.101     00:00:15  6cae.8b2c.2354   Vlan312
10.65.6.109     00:00:15  6cae.8b2c.2354   Vlan312  (
used for tests after ip conflict message and the message continued even changing the ip )
10.65.6.121     00:00:15  6cae.8b2c.272c   Vlan312
10.65.6.202     00:00:18  6cae.8b2c.2b6c   Vlan312
CORSWBETANXS01# sh mac add add  6cae.8b2c.2d88
Legend:
        * - primary entry, G - Gateway MAC, (R) - Routed MAC,  O - Overlay MAC
        age - seconds since last seen,+ - primary entry using  vPC Peer-Link,
        (T) - True, (F) - False
   VLAN     MAC Address      Type      age     Secure NTFY  Ports/SWID.SSID.LID
* 312      6cae.8b2c.2d88    dynamic   0          F    F   Po5
CORSWBETANXS01# sh mac add add    6cae.8b2c.2354
Legend:
* 312      6cae.8b2c.2354    dynamic   0          F    F   Po254
CORSWBETANXS01#
CORSWBETANXS01# show port-channel load-balance
System config:
  Non-IP: src-dst mac
  IP: src-dst l4port rotate 0
Port Channel Load-Balancing Configuration for all  modules:
Module 3:
  Non-IP: src-dst mac
Module 4:
  Non-IP: src-dst mac
Rodrigo Bezerra
was able to fix a bug in the microsoft cluster
Thanks to all
http://support.microsoft.com/kb/969256/pt
