Combined FP and VTP (fabricpath and vtp) NXOS
wim.juste
Dear all,
According to guidelines and limitations for fabricpath switching:
FabricPath does not support VTP when in the same VDC. You must disable VTP when the FabricPath feature set is enabled on the VDC.
What might be the reason behind the fact that VTP must be disabled within a FABRICPATH enabled context?
Since Classical Ethernet (CE) ports might also exist within a fabricpath enabled context.
This would mean one has to create all VLANs manually?
Thanks in advance,
Kind regards,
Wim
0 Replies 0
