Command Configure Terminal Invalid input detected issue
fryda12345
Hi, I can't access to configure terminal. I already have privilege 15. I was trying reset.
Best Regards
Reza Sharifi
What type of this is this? Can you post the output of "sh ver"?
sh ver
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Experimental Version 15.3(20180723:075531) [vipendya 176]
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 23-Jul-18 00:56 by vipendya
ROM: Bootstrap program is C2600 boot loader
BOOTLDR: C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JAY, RELEASE SOFTWARE (fc1)
ap uptime is 1 hour, 26 minutes
System image file is "flash:/ap3g2-k9w8-mx.ap_smr4_esc.201807222357/ap3g2-k9w8-xx.ap_"
Last reload reason:
--More--
Translating "CISCO-CAPWAP-CONTROLLER" to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2602I-E-K9 (PowerPC) processor (revision A0) with 188398K/60928K bytes of memory.
Processor board ID FGL1711Z7JD
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.141.10
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 10:F3:11:9C:F9:08
--More--
Translating "CISCO-CAPWAP-CONTROLLER" Part Number : 73-14588-02
PCB Serial Number : FOC1709597P
Top Assembly Part Number : 800-38356-01
Top Assembly Serial Number : FGL1711Z7JD
Top Revision Number : A0
Product/Model Number : AIR-CAP2602I-E-K9
Configuration register is 0xF
ap#
ap#
