Communication Between Interfaces ASA5506
Valentin GOULET
AHello,
I have a problem between two interfaces of my ASA5506, they don't communicate with each other.
I have the BVI (inside interface) with the address : 192.168.92.254/24
I have two others interfaces that's is not include in my Groupe BV1
The first GE1/7 have the address 192.168.30.254/24
The second GE1/8 have the address 192.168.31.254/30
I can communicate (ping) since my network 192.168.92.X, address of networks 192.168.30.X and 192.168.31.X.
But I can't communicate (ping) since the network 192.168.30.X, the network 192.168.31.X and i can't communicate (ping) since the network 192.168.31.X, the network 192.168.30.X.
I already enable options "enable traffic between two or more interfaces which are configured with same security levels" and "enable traffic between two or more hosts connected to the same interface"
Thanks for your advices
Ruben Cocheno
@Valentin GOULET
your .30 and .31 have different security levels, make those asa 100 to have the traffic flowing.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
@Valentin GOULET
Thanks @Ruben Cocheno
But the problem is the same when I make the security levels at 100 for the two networks
I can’t ping between the network 30.x and the 31.x
