12-27-2012 05:08 AM - edited 03-07-2019 10:47 AM
i purched a cisco Catalyst 3560-CG that is powered by 2960POE switch. my compact switch powers fine but the ports G0/1-8 don't communicate with either POE devises nor a regular computer. i pulled the following information for help diagnose the problem:
Sh version:
Cisco IOS Software, C3560C Software (C3560c405ex-UNIVERSALK9-M), Version 12.2(55
)EX2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 18-May-11 15:35 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3560C boot loader
BOOTLDR: C3560C Boot Loader (C3560C-HBOOT-M) Version 12.2(55r)EX5, RELEASE SOFTW
ARE (fc1)
Switch uptime is 3 hours, 24 minutes
System image file is "flash:/c3560c405ex-universalk9-mz.122-55.EX2/c3560c405ex-u
niversalk9-mz.122-55.EX2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560CPD-8PT-S (PowerPC) processor (revision A0) with 131072K bytes of
memory.
Processor board ID FOC1547W052
Last reset from power-on
1 Virtual Ethernet interface
10 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 0C:85:25:5A:D7:80
Motherboard assembly number : 73-13273-04
Motherboard serial number : FOC15450WV6
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C3560CPD-8PT-S
System serial number : FOC1547W052
Top Assembly Part Number : 800-33671-01
Top Assembly Revision Number : A0
Version ID : V01
CLEI Code Number : CMMEA10BRA
Hardware Board Revision Number : 0x00
Switch Ports Model SW Version SW Image
* 1 10 WS-C3560CPD-8PT-S 12.2(55)EX2 C3560c405ex-UNIVERSALK9-M
Configuration register is 0xF
Show Env all:
TEMPERATURE is OK
Temperature Value: 45 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 80 Degree Celsius
Red Threshold : 90 Degree Celsius
PoE Power - Available:0.0(w) Backup:0.0(w)
Power Source Type Power(w) Mode
Gi0/10 Type1 15.4(w) Available
Available : The PoE received on this link is used for powering this switch and
providing PoE pass-through if applicable.
Back-up : In the absence of 'Available' power mode, the PoE received on this
link is used for powering this switch and providing PoE pass-through
if applicable.
Available*: The PoE received on this link is used for powering this switch but
does not contribute to the PoE pass-through.
Back-up* : In the absence of 'Available' power mode, the PoE received on this
link is used for powering this switch but does not contribute to
sh power inline
Available:0.0(w) Used:0.0(w) Remaining:0.0(w)
Interface Admin Oper Power Device Class Max
(Watts)
Gi0/1 auto off 0.0 n/a n/a 30.0
Gi0/2 auto off 0.0 n/a n/a 30.0
Gi0/3 auto off 0.0 n/a n/a 30.0
Gi0/4 auto off 0.0 n/a n/a 30.0
Gi0/5 auto off 0.0 n/a n/a 30.0
Gi0/6 auto off 0.0 n/a n/a 30.0
Gi0/7 auto off 0.0 n/a n/a 30.0
Gi0/8 auto off 0.0 n/a n/a 30.0
12-31-2012 03:01 PM
I did hard code the speed and duplex on a port and still nothing!!!!
I never asked you to hard-code speed and duplex. I am asking you to run a Layer 1 diagnostics, called TDR.
01-07-2013 02:21 AM
rehello to all, happy holidays and new year,
for the discution i couldn't find any problem at the layer one but if there is a dignostique that i can run that would be great. just to let you know i have a cables RJ45 category 7 indestriel plugued in, tried three different switchs and tried a few computers without any results.
Thank you in advance for any suggestions on this matter
01-07-2013 02:36 AM
I've already mentioned it TWICE. Run a TDR to determine if you have a cable issue or not.
01-11-2013 01:28 PM
Hello i finally run the TDR on my switch and got the following results:
Switch#sh cable-diagnostics tdr interface gigabitEthernet 0/1
TDR test last run on: March 01 00:15:17
Interface Speed Local pair Pair length Remote pair Pair status
Gi0/1 100M Pair A N/A N/A Not Completed
Pair B N/A N/A Not Completed
Pair C N/A N/A Not Completed
Pair D N/A N/A Not Completed
Switch#sh cable-diagnostics tdr interface gigabitEthernet 0/10
TDR test last run on: March 01 00:08:51
Gi0/10 100M Pair A N/A Pair A Normal
Pair B N/A Pair B Normal
Pair C 55 +/- 10 meters Pair C Short
Pair D 54 +/- 10 meters Pair D Short
this is knowing that i am drowing in power from the Gi0/10 and my computer is connected to the Gi0/1
04-12-2013 04:57 PM
Just saw this result today.
G0/10 will NEVER negotiate to 1 Gbps because Pair "D", which controls GigabitEthernet, is "short". You have a cable issue.
I can't determine G0/1 because the result is "Not Completed". You may need to run the test again.
04-12-2013 04:01 PM
The 3560CPD requires a PoE+ or higher power source, PoE won't cut it. The 2960CPD will work with PoE or higher.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960c_3560c/hardware/installation/guide/higoverview.html#wp1420319
