04-22-2015 03:40 AM - edited 03-07-2019 11:40 PM
We need Compare between Cisco 4503E and 3850 Switches and highlights of the 2 switches
04-22-2015 05:11 AM
Against what feature?
What supervisor engine do you want to compare?
Did anyone try to read the Data Sheet?
04-22-2015 05:17 AM
Your question is rather vague.
There are plenty of differences between the two and also plenty of similarities.
As Leo has said, it would be worth starting with the data sheets.
You need to understand what your actual requirements are first.
04-22-2015 05:47 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Devils Advocate has noted, there are differences and similarities. And as Leo has noted, a 4500 supervisor is a point of comparison (a rather important one). Choice of line cards, in the 4500 series, also are a point of comparison.
A couple of major differences, though, are due to their basic architectures. The 4500, in the smaller chassis, like the 4503, do not support sup redundancy, while once you stack 3850s, you have "sup" redundancy.
The 4500 sup provides a real fabric between line cards, while the 3850 provides a "special" stack ring between stack members.
IMO, the 4500 is a much more stable (mature) product, also sold as "carrier grade", while the 3850 (still rather new!) are more suited as edge switches.
Besides "paper" features, much would depend on what role you wanted to use either switch in, and how critical such usage was to your business. For example, I would be a bit nervous using a 3850 for a core or distribution L3 role, but might lean toward using a 3850 as a high performance/capacity L2 user edge.
