compatibility with "3M IBM PASSIVE DAC SFP+ CABLE"
kikeabcd2
Hi Community
I would like to know if the module
- Network module 3850-NM-2-10G
Is compatible with the cable
- 3M IBM PASSIVE DAC SFP+ CABLE (LENOVO)
Or advise me to buy another cable?
Thanks for the help
Reza Sharifi
The switch module is compatible with Twinax cable, but have never used this particular brand.
see link and look under "Catalyst 3850 series"
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
If you already have the cable, you can try it, if it does not work, order one that is compatible with Cisco switches.
http://www.fs.com/products/30862.html?currency=USD&paid=google_adwords&gclid=CjwKEAiA_9nFBRCsurz7y_Px8xoSJAAUqvKCzNz7BLZuR1uQSMc0U7h0w-rE1eNYOH1UBL0gY1jAYxoC6Pjw_wcB
