02-07-2014 07:47 AM - edited 03-07-2019 06:04 PM
I need help to determine if the modules WS-X6716-10GE and CVR-X2-SFP10G, I refer to the matrix compatibility and there isn´t any informtation about this module specifically.
Thanks for the help.
Solved! Go to Solution.
02-07-2014 03:18 PM
It is supported. Have a look at table 6 in the same link
VS-S720-10G-3C
VS-S720-10G-3CXL
WS-X6708-10G-3C
WS-X6708-10G-3CXL
WS-X6716-10G-3C
WS-X6716-10G-3CXL
(With CVR-X2-SFP10G converter for X2 ports)
02-07-2014 03:18 PM
02-07-2014 03:43 PM
Hi Reza, thanks a lot for the help I don´t see that detail.
