05-03-2012 11:55 AM - edited 03-07-2019 06:29 AM
hi for conexion vss two 6506 which is the conector or speed (10g or1g) Sfp or x2
What is the connection that allows vss
05-03-2012 12:03 PM
First of all you will need Sup720-10G. Futhermore the VSL link is treated as a systems control link and encapsulates all traffic into a special system header called the Virtual Switch Header (VSH). This encapsulation is done via dedicated hardware resources and the VSL can only be configured on a 10-Gigabit interface with following hardware ports:
•Sup720-10G, 10-Gbps ports
•WS-X6708
•WS-X6716 (in performance mode only, requires 12.2(33)SXI)
All having 10Gbps and X2 modules
Dan
05-03-2012 12:09 PM
Supervisor 2T is also support VSS, as far as newest line cards.
05-03-2012 12:06 PM
Only 10G EtherChannel. You may use Supervisor ports or line card's ports (X2 or XENPAK) with some restrictions.
05-03-2012 01:54 PM
Tks had no found that specification
