Config advise requested from Experts
info
Hello all I'm looking for a bit of advise.
Please see the attached network topology, I'm looking for opinions on the best configuration based on performance and security. I welcome any suggestions that the experts on the forum can provide to assist with this config.
I would also welcome any suggestions to avoid bottleneck or loops.
Thanks in Advance,
It will be a pleasure to assist you with your request   :-)
The attached diagram displays a point of failure, if you Core device is down, your entire network will be affected. Always try to have high availability, redundancy, scability, security, performance.
You could use the 3 layered model: Core, Distribution and Access. Also have a couple of switches for the server farm. Collapsed core model with access switches also could be used.
Firewalls can be used on the perimeter to protect your network of attacks from outside.
These links can be useful:
http://www.networkcomputing.com/data-centers/campus-network-design-models/1685370612
 https://www.google.com/search?q=cisco+enterprise+architecture+model&client=firefox-b&biw=1366&bih=659&tbm=isch&tbo=u&source=univ&sa=X&sqi=2&ved=0ahUKEwiHnsSE4YPSAhVC4CYKHeXXBL4QsAQIIg#imgrc=a_T9lKu-QO98MM:
Please rate the comment if it is useful   :-)
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
