config not supporting
Richard.Jeff
Dear All,
My 7206 router is running the ios c7200-a3jk9s-mz.124-25b.bin and the same support the configuration mgcp behavior g729-variants static-pt
When I upgrade the image to c7200-adventerprisek9_sna-mz.124-4.T7.bin its not supporting the above command instaead throws the error as below:
R1(config)#mgcp behavior g729-variants static-pt
% mgcp behavior g729-variants static-pt: Undefined parameter(s). Suggest:
  auep v0.1
  ack-init-rsip disable
  signals v0.1
  init-rsip-per-insvc legacy
  q-mode-enduring legacy
  dlcx-clear-signals all
  dlcx-clear-requests all
  provisional-acks legacy
  rsip-range tgcp-only
  mdcx-sdp ack-with-sdp
Could anyone let me understand if this new image is not supporting this config or what is the equivalent configuration for this....
Richard
p.mcgowan
Level 3
Level 3
Richard,
Can you please confirm the IOS versions, you say you have upgraded from 12.4(25b) to 12.4(4)T7
Looks like you have downgraded your router. is this correct or is there maybe a typo??
