Beginner
Configuration for Cisco 871 to work with an ISP provider for home or work
Good Day,
I just wanted to post a configuration that I did on a Cisco router 871. This configuration works for me. It is used for a non statis IP address or dynamic address from the Internet service provider. You need to have Nat configured and enabled on your router or routing switch for this to work. I find that it is hard to find a complete configuration listed with the right configuration on the web.
Je publis ici la configuration d'un routeur Cisco 871 pour qu'il fonctionne avec un fournisseur d'accès à l'Internet. Cette configuration fonctionne avec une une adresse dynamique.
sh run
Building configuration...
Current configuration : 3943 bytes
! Last configuration change at 21:13:54 UTC Fri Mar 1 2002 by admin
version 15.1
no service pad
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname hostname
boot-start-marker
boot system flash:c870-advipservicesk9-mz.151-4.M6.bin
boot-end-marker
logging buffered 25000
aaa new-model
aaa session-id common
dot11 syslog
ip source-route
ip dhcp limited-broadcast-address
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp pool local
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
ip cef
ip domain lookup source-interface FastEthernet4
ip address-pool local
no ipv6 cef
username admin privilege 15 password 7 0B5A435C13
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
description ISP
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip broadcast-address 192.168.1.255
ip nat inside
ip forward-protocol nd
no ip http server
ip http secure-server
ip dns server
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
banner motd ^C
Unauthorized Access Prohibited                     Acces non-autorise Defendu
Access Monitored                                               Acces surveille
^C
line con 0
exec-timeout 30 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 30 0
transport input all
scheduler max-task-time 5000
webvpn context Default_context
ssl authenticate verify all
no inservice
end
That it. I am still learning hoe NAT works in this case. It creates a new interface that allows you to route to the Internet. If NAT is not configured it will not work.
Hope this help
Content for Community-Ad
July's Community Spotlight Awards
