Configuration Professional for Catalyst, Release 1.3
itdeptkauf
http://www.cisco.com/c/en/us/td/docs/switches/lan/cisco_cpc/release_1_3/release_notes/CiscoCPC_rel_1_3.html#pgfId-242504
I have C2960-24TC-L running 15.0.(2).SE10a and 2960-48TC-L running 15.0(2).E6 switches.
Minimum supported version for these models for Configuration Professional for Catalyst is 15.2(5)E1 as far as i can see, but newest version for my switches is the above mentioned, a lower version.
1. Is this release supported on my equitment?
2. If, do the update require a reboot?
Robert
g.fabre
Configuration Professional for Catalyst is one of the less documented feature on Cisco... I can't even figure out if this is an embedded software on the switch of it is using a dedicated external application to run...
on addition, no page mentions how to upgrade; I think that Cisco doesn't really want people to use it
