Configure jumbo frame on Nexus??
CiscoPurpleBelt
Frequent Contributor
If you need to configure Jumbo framing to ports that are assigned to L2 port-channels on a Cisco Nexus 5k, should you configure it on the actual port-channel or the actual physical interface? Will making this change cause any disruption?
3 Accepted Solutions
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
On the 5ks, configuring the Jumbo frame is a global policy which means it applies it to all physical interfaces. See link:
https://www.cisco.com/c/en/us/support/docs/switches/nexus-5000-series-switches/112080-config-mtu-nexus.html
Thing is, when I look at show running=config all is shows 1500 MTU under the port-channels and applicable interfaces.
If you want to see the correct jumbo frame size, try this command:
sh queu interface x/x
or
sh queu interface x/x det
you should be able to see mtu 9216
Good Luck!
Not sure if the Portchannel will show the cumulative numbers but I think as long as you see them on individual interfaces, you should be good to go.
11 Replies 11
balaji.bandi
VIP Community Legend VIP Community Legend
You need to configure the interface level is suggested, yes it will be a small convergency time to negotiate.
BB
I dont have any options for "mtu" or anything like that on the interface. Any ideas?
I was provided 7K information, 5k it was global config :
BB
Reza Sharifi
Hall of Fame Master
Yes I caught that. I got this in the running config so I belive it is already enabled?? Thing is, when I look at show running=config all is shows 1500 MTU under the port-channels and applicable interfaces.
olicy-map type network-qos jumbo
     class type network-qos class-default
     mtu 9216
     multi-cast optimize
systesm qos
     service-policy type network-qos jumbo
Thanks again Reza. See my previous reply?
or
Good Luck!
Yes sir thanks again.
One one of the applicable port-channels for this interface, I don't see much jumbo packets however I see many packets on the associated interfaces. Should I not see the cumulative number of packets on the port-channels for these interfaces?
CiscoPurpleBelt
Ok thanks
Recognize Your Peers
