Join Customer Connection to register!
562
mburguk1000
Beginner
Configure WCCP on a 4510 switch
I have to configure an instance of a WCCP on a 4510 switch and I have to admit  have read the examples given by Cisco but dont have understanding of the example config
Router(config)#
ip wccp web-cache group-address 224.1.1.100 password alaska1
I have attached the config in question above and could someone please clarify what the group address  224.1.1.100 is ?
Many Thanks
Mark
20 REPLIES 20
Jon Marshall
Hall of Fame Guru
Mark
The multicast address is used when you have multiple routers/L3 switches using the same service group. So instead of the cache engines having to send protocol messages to each router you can use a multicast address instead.
It is optional and you don't necessarily need to use it if you only have on L3 device actually responsible for WCCP.
Jon
Hi Jon thanks for the prompt reply but Im still a bit unsure of what syntax I would use to get this working ?
Mark
Mark
Is it just for http ie port 80 traffic or other traffic as well ?
Jon
Mark
In addtion where are the clients in relation to the proxy eg. which vlan(s) etc.
Jon
It is for HTTP and HTTPs and the clients are on a Layer 3 Vlan if that helps
Mark
Mark
web-cache is for http only. You could use this and then use a service group for https but it might be easier to simply use a service group for both so -
client vlan = vlan 10 = 192.168.5.0/24
4500 config
ip wccp redirect list 101 password
int vlan 10
ip wccp redirect in
access-list 101 permit tcp 192.168.5.0 0.0.0.255 any eq http
access-list 101 permit tcp 192.168.5.0 0.0.0.255 any eq https
note if you use a password then obviously this needs to be configured on the proxy as well.
The above assumes the proxy is not in vlan 10.
Jon
mburguk1000
Beginner
That is very helpful thank you for time and trouble
Hi Jon I have tried what you said and still cant get it to work
The syntax doesnt even alloe me to configure a redirect list ??
Mark
Mark
Sorry, the syntax should be "redirect-list" not "redirect list"
Does it give you that option ?
Jon
Whay happens is I enable wccp version 2 and then syntax prompts 3 options
<0-254>    Dynamically defined service identifier number
  version    protocol version
  web-cache  Standard web caching service
Do you mean when you do -
"ip wccp ?"
If so see previous answer where i posted the configuration  ie. you need to define a service group number, any number is fine in that range.
If not then what IOS version and supervisor are you using ?
Jon
The syntax i have is "ip wccp 0 group-list proxy_users (which is my access list to specify who goes through proxy) and then I get prompted to add group address ????
its IOS 12.2 (54)SG1 and supervisor 1V
and its a cisco 4507 switch
