06-08-2015 06:57 AM - edited 03-08-2019 12:27 AM
Can we configure HSRP for LAN core high availability on the Cisco WS-C4507RE-S7L-96 (Primary switch with universal crypto image) & Cisco WS-C4506E-S7L-96 (secondary switch with universal image).
06-09-2015 10:25 AM
Post moved to appropriate community: Enterprise>LAN, Switching and Routing
06-09-2015 10:40 AM
Yes, the switches do not need to be the same chassis.
In fact with HSRP you can use completely different models of switches if you wanted to.
Jon
06-10-2015 05:29 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
To extend what Jon has described, basically as long as the two devices support a compatible version of HSRP (or GLBP or VRRP), the hardware of those devices doesn't matter.
06-09-2015 10:47 AM
What is the License level on these, I think you may need the ip base license on it to configure HSRP.
Share me a sh ver from both.
Hope this helps.
Madhu
06-10-2015 04:52 AM
Please find the below sh version from both the switches
ESI-CORE01#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.03.02.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 23-Oct-12 23:51 by prod_rel_team
ROM: 15.0(1r)SG10
ESI-CORE01 uptime is 16 weeks, 1 day, 2 hours, 41 minutes
Uptime for this control processor is 16 weeks, 28 minutes
System returned to ROM by SSO Switchover
System restarted at 07:30:02 IST Wed Feb 18 2015
Running default software
Jawa Revision 7, Winter Revision 0x0.0x40
Last reload reason: Reload command
--More-- compliance with U.S. and local country laws. By using this product you
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP7L-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4507R+E (MPC8572) processor (revision 6) with 2097152K/20480K bytes of memory.
Processor board ID FXS1834Q4L5
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from Reload
20 Virtual Ethernet interfaces
152 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
ESI-CORE01#
ESI-CORE02#
ESI-CORE02#
ESI-CORE02#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.03.02.SG RELEASE SOFTWARE (fc1)
Compiled Wed 24-Oct-12 00:32 by prod_rel_team
ROM: 15.0(1r)SG10
ESI-CORE02 uptime is 8 weeks, 6 days, 2 hours, 38 minutes
System returned to ROM by reload
Last reload reason: Unknown reason
License Level: lanbase Type: Permanent
Next reboot license Level: lanbase
cisco WS-C4506-E (MPC8572) processor (revision 6) with 2097152K/20480K bytes of memory.
Processor board ID SPE184500K8
2 Virtual Ethernet interfaces
148 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
ESI-CORE02#
06-10-2015 12:05 PM
HI,
Agree with other experts view on this.
1- you dont require to have the same model/version to run the HSRP.
2- From my point of view you should be good to run the HSRP between these devices.
3- Please go ahead and configure the same and let us know in case if you face any problem and we will help you on the same.
Inayath
06-10-2015 12:05 PM
Hi Inayath,
I have not tested this, but are you saying LAN Base support HSRP.
I just looked at the feature navigator, i did not see HSRP. Also looking at the below
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_26675-01.pdf
It says you need IP BASE. Just curious to see you experienced this before or tested it?
Madhu.
06-10-2015 06:02 PM
Madhu,
I overlooked it and didnt see the other one.
1st one.:-License Information for 'WS-X45-SUP7L-E'
Next reboot license Level: ipbase >>> didnt look at the other one.
Thanks for pointing. Yes it does need min IP Base to run the HSRP.
Inayath
