Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi thereI am assigned to check the issues with this attached network and have managed to remove some hups and redesign the network to what it is now. there were no vlans and it has been configured. the issue is that the internet speed is extremely sl...
Does the Catalyst 2960-X or 350-P network switches have internal coin cell batteries to retain memory or clock settings? If so, what is the part number of this battery. Alternatively do you have a safety compliance document for the battery which allo...
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
Hello Community,I am looking a script for switches cisco for block interfaces with APs connected , the reason is because we receive daily port changes and sometimes the engineers change the vlan Wi-Fi by another and the Wi-Fi environment is affected ...
hi friendsi config below commands to configure AAA authenticate with Microsoft Active Directory 2008(CIsco Device Integrate with AD microsoft for telnet and ssh and both can login to console by AD and local username) but while i unplugged Cisco Devic...
zavira123 by Level 1
  • 54297 Views
  • 13 replies
  • 1 Helpful votes
Hi Team, Two switches are connected to each and that link is a trunk port between those two switches, The challenge is on one switch when I perform cdp/lldp neigbor detail I can see the other switch which is connected to it but funny thing when I pin...
Hi,I have a C9200L-48P switch with 4x1G uplink module.Port Gi1/1/1 does not have an LED blinking when connected to another switch.Ports Gi1/1/2-4 seem to work fine.Could anyone please guide me on troubleshooting the port and also advise action?
Ranjita by Level 1
  • 135 Views
  • 5 replies
Hi All,I came across a strange issue today. I have a C9300-48S-A Switch but the show version output of the switch shows that the switch has an Essentials license on it.Below snap for quick ref: Is this an error from Cisco or have I missed something?A...
Ranjita by Level 1
  • 86 Views
  • 2 replies
I  wanted to test a local account on a Nexus switch and bypass the radius (ssh)connection. To do so, I add the  aaa authentication login default local  I am now able to access the local account but I wanna get back to the previous configuration. When...
MJ666 by Level 1
  • 87 Views
  • 3 replies
