Configuring L3 switch as default GW behind ASA Firewall
Dunner1991
Beginner
Beginner
Hi All,
I am in the middle of moving my Default GW for office users from my ASA down to cisco (L3) switch.
I need this traffic to hit the Default GW and then need to set a default route back to the firewall
I wanted to create an SVI on the switch for the GW IP
The issue i have is that on the same switch there is already an SVI configured on vlan 1 in the same range as the Default GW so I don't know if what I amtrying to do is possible
I am unsure what other options there to help implement this solution
1 ACCEPTED SOLUTION
chrisjoyce1980
Beginner
Beginner
Myself, I would create a new transit network/vlan between the ASA and the L3 Switch.  I would use this network to route/forward traffic requests.
Configure the L3 Switches default gateway as the ASA. (i.e. ip route 0.0.0.0 0.0.0.0 172.16.0.1)
For the ASA, configure routes for the internal network on the L3 Switch (i.e. route inside 10.0.0.0 255.0.0.0 172.16.0.3)
Or you could use OSPF or EIGRP for Dynamic Routing, rather than configuring static routes.
For Example: ASA
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 172.16.0.1 255.255.255.248 standby 172.16.0.2
route inside 10.0.0.0 255.0.0.0 172.16.0.3 <route back to your internal network/subnet(s)>
For Example: SW
VLAN: 999
NAME TRANSIT-NETWORK
interface Vlan999
description Routed WIFI-AP VLAN 10.232.72.0/22
ip address 172.16.0.3 255.255.255.248
no ip redirects
no ip proxy-arp
no ip unreachable
ip route 0.0.0.0 0.0.0.0 172.16.0.1 <route to anything that isn't local to the L3 switch>
1 REPLY 1
chrisjoyce1980
Beginner
Beginner
For Example: ASA
nameif inside
security-level 100
For Example: SW
VLAN: 999
interface Vlan999
no ip redirects
no ip proxy-arp
no ip unreachable
