Configuring logging on 6807 for interface down
dbuckley77
We have a 6807 switch that we're sending traps to a syslog server from.  The interface down traps are not getting sent.  below is the logging config
logging trap notifications
logging source-interface VlanX
logging host 10.100.XX.XX
luis_cordova
Hi @dbuckley77 ,
You could check if this command helps you with it:
Within the interface configuration
(config-if)#logging event link-status
Reza Sharifi
Can the switch communicate with the syslog server? Does the syslog server receive any other messages?
