04-17-2014 01:11 AM - edited 03-07-2019 07:08 PM
When I need to change protected mode in true after switchport I don't see syntax of this command ?
Switch(config-if)#switchport ?
access Set access mode characteristics of the interface
mode Set trunking mode of the interface
native Set trunking native characteristics when interface is in
trunking mode
nonegotiate Device will not engage in negotiation protocol on this
interface
port-security Security related command
priority Set appliance 802.1p priority
trunk Set trunking characteristics of the interface
voice Voice appliance attributes
04-22-2014 06:59 AM
Hi gogomilky,
What is the output of show ver on this switch, I think it may be the IOS version that is the problem, not your command.
Best wishes
Mike
04-27-2014 09:19 AM
As mentioned by Luckymike33, it would be helpful to know which IOS version your switch is running.
05-02-2014 08:48 PM
Hi gogo,
Pl let us know switch model and IOS version.
CSA...
05-15-2014 12:34 PM
details of ROM IOS:
ROM: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)FX, RELEASE SOFTWARE (fc4)
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24TT 12.2 C2960-LANBASE-M
05-16-2014 09:12 AM
Gogomilky,
Allow me to correct you. That's not the IOS version.
When you do a "show version", look for the line where it says: "System image file is "flash:/...."
05-17-2014 01:39 PM
Wass,
You are wrong, SW IOS version is 12.2 and *.bin extension is only file which hold IOS. The full name of flash is: flash:/c2960-lanbase-mz.122-25.FX.bin
From full path of bin file how can you conclude on which the version of IOS works ???
05-17-2014 06:31 PM
hi,
i don't think it's supported on the 2960. although it says 12.2(25)FX and later supports PVLAN edge but i believe that might be an inconsistency on some cisco docs.
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/10584-63.html
i also don't see it on cisco's feature navigator (cisco.com/go/fn). if you click on 'Private VLAN - Edge' it shows you 1800 platform (not sure why). see attached.
still can't do copy/paste thing using the new CSC format. not sure why they've removed it.
05-19-2014 05:42 AM
Gogomilky,
Maybe I was wrong as you said 🙂 But what I know is, in order to show the IOS version being used, a quick way is to do a "show version" and look for the full name of the IOS
To support my answer, check this link
05-15-2014 12:37 PM
Also I had PT 6.0 and pipe "|" don't function on either IOS version 12.XXXX and 15.XXXXXX (Version 15.1(4)M5)
Why ?
