Configuring "system mtu jumbo" during production?
Martin Erman
Beginner
Beginner
Hello.
Will changing
system mtu jumbo
from 9000 to 1500 disrupt the network if done during production?
Martin
ajay chauhan
Rising star
Rising star
Martin-Reset the switch afterwards for the MTU change to take effect.
Ajay
5 Replies 5
mohseen patel
Beginner
Beginner
Hi Martin,
What device you are planning to make this change ?
Br.
Mohseen
It is on a:
WS-C3750E-24TD
Hi Martin,
You already have answer but just FYI on 3750 jumbo frame is only supported on Gigabit Ethernet ports.
Br.
Mohseen
ajay chauhan
Rising star
Rising star
Ajay
Ok, thank you.  Will have to do it during planned downtime then.
/M
Recognize Your Peers
