configuring vlans and trunking on a 1900 switch
carl_townshend
Can anyone tell me the easy way of doing this and if its possible ?
cheers
Carl
mahmoodmkl
Level 7
Level 7
Hi Carl
u can create vlans from config mode.
As per trunks u have to go into the interface mode and use
trunk on command.
Mahmood
thanks, can you give me the command for this ?
cheers
Carl
Hi Carl,
Cat1924-EN#configure terminal
Cat1924-EN(config)#vtp domain DOC
Cat1924-EN(config)#vtp client
Cat1924-EN(config)#int fast0/27
Cat1924-EN(config-if)#trunk desirable
Check this link for trunk configuration on 1900 with 6500
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a0080143c38.shtml#configs
VLAN/VTP configuration guidelines
http://www.cisco.com/en/US/tech/tk389/tk689/tech_configuration_guides_list.html
HTH, rate if it does
Narayan
Hi Carl,
I believe you must be having a Menu based 1900 switch if yes have a look at this link which will guide you how to configure vlan and trunk from different menu based options
http://www.cisco.com/univercd/cc/td/doc/product/lan/28201900/1928v9x/ee_scg/1vlans.htm#xtocid2880523
Ankur
