configuting vlan1
ramakanth
Frequent Visitor
Frequent Visitor
i have configured the vlan1 as 10.10.0.31 to the switch 2960
now i want to disable the vlan1 and create a new vlan99 and route the traffic through that vlan
can any body give me the answer how to do the following steps
Georg Pauwen
2960#conf t
2960(config)#int vlan 1
2960(config-int)#shut
2960(config-int)#exit
2960(config)#interface Vlan 99
2960(config-int)#ip address x.x.x.x y.y.y.y
Hello
If this switch is going to be your core switch then the following example:
conf t
int vlan 1
shut
int vlan 30
ip address 10.10.10.31 255.255.255.0
no shut
exit
vlan 99
exit
ip routing
If this is just a access switch same as above but disable ip routing and provide it with a default gateway.
no ip routing
ip default-gateway 10.10.10.x <--- ip address of core switch vlan 99
Kind Regards
Paul
