Confirming amount of power used by 6509
RonaldNutter
I am trying to find a way using CLI that I can identify the amperage being used by a 6509 chassis.  I have looked through all of the sh power and sh env commands and seem to only find the power being used on the DC side (since the output referemces 42V).   Ddint know if there was something I was overlooking.  To each things from the AC side will take getting an electrician in which is what I was hoping not to have to do.
Ron
I doubt if there is anything like that on the CLI.
I would draw you to the following link to help you calculate how much power your 6500 is drawing.
http://tools.cisco.com/cpc/
Try the command....
show power used
Mike
or if it is running VSS then try
show power switch 1
show power switch 2
Mike
ooop! sorry should have read the post more carefully....you tried that already.
Mike
