connect 2 switches
I have 2 unit of WS-2950T. Each switch Giga1 I configured trunk mode.
Connect using straight cable --> no light
Connect using crossover --> got light. Connected. Ping other sw OK!
Do really need to use cross? i thought cisco sw auto detect?
2 Accepted Solutions
shillings
Level 4
Level 4
Hi Mohd. It's an old switch now and doesn't feature Auto MDIX - i.e. Yes, you do need a crossover cable.
cadet alain
hi,
2950 switches do not support autoMDIX so you need a crossover.
Regards.
Alain
shillings
Level 4
Level 4
cadet alain
hi,
Regards.
Alain
