Connect GBIC to SFP
Luis Alvarez
Hello everybody.
Ok. here is the question. Is it possible to make an uplink between a Cisco Catalyst 3550 switch (via 1000BASE-T GBIC model WS-G5483) and a Catalyst 2960 switch (via 1000BASE-T model GLC-T SFP module or it's gigabit Etherner ports)?
Best Regards
Luis Alvarez
edsge teenstra
Hi , just tested it for you , yes it works , WS-C2960-24TT-L & ws-g5483 & WS-C3550-48-EMI connected together with the rj45 10/100/1000 port ,see logs attached :
cheers & good luck
Edgse
edsge teenstra
cheers & good luck
Edgse
Thank you very much!
Best regards
Luis Alvarez
mohamedtag
We are connecting the same 2 Devices but with a Fiber Cable SC-LC ( SC from 2960 End ) and ( LC from 3550 End ) and it works with No Problem.
Thank you Very much!
regards
Luis Alvarez
