Connect wan-lan routers
venominus
I need to connect lan to wan by 2 routers, wireless router on the left side is lan and internet is on the right side, how to configure routers?
Hi there,
you can use default route in wireless router which located to internet router connected interface ip address. in internet router you should add static route destined to local network and destination ip address as a connected interface in wireless router.
regards,
kasun
Good luck
KB
