Connecting a router to two switches via fiber
kenlorenzo
Hi Guys, I'm trying to connect 1 ASR router to two switches via fiber ethernet for failover.
Essentially, i want to use two interfaces, 1 ip address, and split each connection between two switches so the router is still reachable if one switch goes down.
I just noticed that I cannot use the bridge-group command on the fiber interfaces. I've done this for UTP Gigabit interfaces for another. router.
Is Etherchannel possible across two separate switches?
Thank
shijogeorge
Etherchannel across two switches is possible; provided you are using any of the following technologies at switch side.
vPC- Nexus 7k, 5k
VSS- Cat 6500
Stack- 3750, 2960S
Shijo George
