05-20-2016 04:46 AM - edited 03-08-2019 05:51 AM
Hey all,
My customer has a 6500 10G port using a XENPAK-10GB-LX4 and needs to connect to a F5 BigIP load balancer that uses a SR equivalent SFP. Assuming they use different wavelenghts (1310 for the LX4 vs. 850 from the SR), I need to confirm if this will or will not work (I believe it won't).
Persio
Solved! Go to Solution.
05-20-2016 05:18 AM
It won't as is; but you will have to get a proper Xenpak and it will.
LX uses laser technology, single mode fiber, very tight and narrow beam of light.
SR is surface mount LED, multimode, and much broader beam.
End-to-end have to match, or the light path simply doesn't make it through reliably. Even one incorrect fiber patch cord can mess things up.
05-20-2016 05:18 AM
