02-24-2015 07:35 AM - edited 03-07-2019 10:49 PM
Good afternoon to everyone!
I have a technical question which is this:
I have two AIR-CT8510-100-K9 controllers and I have two WS-C3850-12S switches.
I want to connect one AIR-CT8510-100-K9 with WS-C3850-12S switch and I want to connect them with 10G speed.
I guess that in WS-C3850-12S I must put C3850-NM-2-10G module and CT8510 has two 10G ethernet ports.
I want to ask now: Can I connect them directly with CAT 6A ethernet cable (10 gigabit) or I must connect then with SFP modules?
If with SFP modules, can I insert in C3850-NM-2-10G a SFP module or it accepts only ethernet cable?
Thank you!
Solved! Go to Solution.
02-24-2015 03:32 PM
You can connect them using either one of these:
Read more HERE.
Be aware the cables have a length of 1 metre, 3 metres and 5 metres. If you have something to go further, you'll need fibre optic cable (OS2 or OM3/OM4).
02-24-2015 03:32 PM
Read more HERE.
02-24-2015 11:10 PM
But does the SFP-H10GB-CU3M have SFP+ on each side of cable or no? On the picture I see that they have, but pircures are sometimes not good :)
If they have SFP+, are those SFP+ compatible to connect, one in the back of CT8510 and other in C3850-NM-2-10G?
Thank you!
02-25-2015 12:25 AM
Ok, I may have given you the wrong information.
The 8510 will only support SFP-10G-LR or SFP-10G-SR.
