Switching
Get 20% off switches when you combine Cisco solutions
Labels
hi guys . i have a network with below topology. In the core layer, I want to have redundancy, which means that if the main core switch of my network has a problem, the backup switch will automatically enter the circuit. What method is there?
chpmotry by Level 1
  • 80 Views
  • 5 replies
Hi A costumer is asking us how much heat a 3650 switch are producing to calculate the HVAC for cooling. We are cheeking the DATA-SHEET but the only information about this is is the Airflow and Operating temperature. Anyone knows where we can find thi...
We are seeing random high memory utilisation spikes on our Cisco 9200L switches, running version 17.9.4a. We thought this might be related to the application visibility that is pushed out to them via Cisco Catalyst Centre, so we disabled application ...
Hello everyone, I have two cisco 3750 switches that are on stack with the below config Switch# Role Mac Address Priority State--------------------------------------------------------*3 Master 0017.5ae7.d500 1 Ready4 Member c062.6b8c.f200 1 Readyi wou...
joe5084 by Level 1
  • 61 Views
  • 1 replies
Hi All,I have a topology as shown below:The Firewalls A & B are running as active/standby. I have an etherchannel configured between L3 Switch A and Switch B. The switches also have HSRP running for various VLANs. The link between Switch and Firewall...
Ranjita by Level 1
  • 93 Views
  • 0 replies
  • 1 Helpful votes
