Hello all,
A client of ours recently purchased 2 SF300-48P switches with the intent of expanding their network beyond their current configuration. We currently have a 2811 series router that connects into a 3560G. The link between the router and switch curerntly passes 4 VLANS including one for voice. The current setup is fairly standard. Subinterfaces on the 2811 with dot1q Encaps and the 3560 set to trunk with dot1q encapsulation.
I have tried to find how to get the 3560 and SF300 switches to talk across a trunk port. All the docs I've come across say that the SF300's use GVRP instead of dot1q trunking. I am also unable to locate info on how to have to have the SF300 talk to the 2811 using the same VLANs.
Any help or nudge in the right direction would be much appreciated. I've never used this type of switch prior. From my understanding it is rebranded LInksys SWR series switch.
